The main screen on the Wyze app shows a list of all of your devices that you have under control. How about a way to re-order those devices. Currently, when you add a new device, it shows up at the top of the list. If I have several bulbs, plugs and cameras, I might want to group all of the cameras together as well as the bulbs and plugs. Now, they show up in a jumble of devices.
You can reorder your devices in the app now.
Follow these steps:
- Tap the pencil icon in the upper right corner of the home screen
- Tap edit devices
- Press and hold the three bar icon on the right side of each device. Slide the device up or down to where you wanted to appear in sequence on your home screen
- When finished tap Done in the upper right hand corner
This should reorder your devices on your Home screen.
[Mod Edit]: Your post was merged to this category since it involves a question and not a request for a Product or Service enhancement by Wyze.
Thank you, I have 7 cameras and have been trying to figure this out…re-ordered now, got my new V3’s on top where they should be and re-ordered the older cameras with the V1 on the bottom. I had removed a couple of them and when I re-added, they moved to the top.
