I would like a way to reorder the devices in the screen. Maybe an option to put items together (cams, plugs, lights, etc.).
On the main screen, click the pencil in the upper right corner and then select “Edit Devices”. That will bring up your devices. The two little lines to the right of each device can be used to grab and rearrange the devices. When you are completed, click “Done” to save your changes.
Wow! Never saw that. Worked like a charm. Thanks
Welcome rsaxer.
Lots of helpful info on the Support site:
And I also finally found this post and it worked great in app on cell , but now my question is , how do I re-arrange the order of cam+ devices in the Wyze Cam Portal on my P.C.
You can’t, Wyze hasn’t made that option available yet.
Well , what appears to be the deciding factor(s) in selection of order ? Could it be that they are alphabetically decided ? I only have 2 Cam+ subscriptions and really need the order presented on P.C. display to be reversed , I am even willing to rename them if they are in order of alphabet .
Anyone know ?
As I said, that option is not available yet. There is no rime or reason how they are displayed. I remember vaguely that someone on this forum managed to reorder them but he went into the source code of the browser. I’v tried myself but it didn’t work for me.
Just in the app.
You can drag&drop camera sorting manually on the live.
I am also trying to reorder the thumbnails, but I do not see a pencil tool anywhere.
