Is there some way to reorganize the Wyze App Home screen? There is a mix of cameras and plugs in somewhat random order. I’d like to organize the smart plug that goes with that specific camera. Thx.
Yes, tap.on the pencil at the top right. Then select Edit Device.
From there you can drag your devicea up o down and put them in the order you would like.
Thanks - I tried that on my iPhone, but the display shows all the cameras, with a red (delete) icon to the left, a ‘hamburger’ icon on the right which is unresponsive. When I try to move, nothing happens.
