Raspberry - Octoprint - Need Help for URL / HTTP://
I have these models.
Wyze Cam Pan V3 - Wyze Cam AND Telephoto - Wyze Cam V3 Pro
I use a RaspBerry Pi 4b and Octoprint for m my 3D printer. There is a streaming camera. See the picture.
I would like to be able to connect 2 of my Wyze cameras, but don’t know what the URL should look like for it to work.
Hoping that someone in this forum will take the time to help me
If I don’t have explain my problem not good enough. Her is a pages with more informations:
Wyze cams don’t provide a RTSP url. You can use the RTSP firmware for the v3 (not pan), but it has been unsupported for a long time and probably doesn’t even work.
The ideal solution is to use Wyze Docker Bridge. It’s a community project, but I have heard that it works great and many users use it.
Good luck!
Another option is Tiny Cam Pro and then run it as a “Server” which will then give you a URL for the cam when streaming locally.
But I agree with IEatBeans that Docker Wyze Bridge is the best solution to get an RTSP URL from the Wyze cams.
