Question
I have three cameras hooked up and I am trying to get SD cards for them. I am just confused on if I need an SD card for each camera, or if I can use one SD card for all three of them.
@silfredov Welcome to the Wyze community! You will need to buy a microSD card for each cam. See photos on how to install the cards in the cams.
For best performance, it’s recommended to use 32 GB High Endurance microSD cards with video cams.
https://www.amazon.com/dp/B07B98GXQT/ref=cm_sw_r_cp_tau_Pxc4Eb9AAN372
Thank You So Much.
You’re welcome! :slightly_smiling_face:
