What is your sensitivity set at for your home camera and what is it at for your camp camera?
Around 25 to 30
Try bumping it up OVER 50% & see if you get any notifications.
Bumped them up. Also when I am in WiFi I receive them once in a while. But when I am only in very good cell service I donāt receive any. Itās like the cloud isnāt pushing the notifications to me.
The ones at my home work great. If Iām home or not home I always get notifications.
Well then that sounds like a cell service issue, not a Wyze issue!
Tough to get anything if you donāt have good service. ![]()
That was my conclusion on this issue as well.
Cell service is great. Full bars. I had no problem when first setup. Received notifications fine. Updated firmware on the cameras and then it quit working.
I receive events just no notifications and says it play clip
Why do my other cameras work at home or away from home
Iām using the new update as well, and I didnāt experience any notification issues after the update. I wish I knew what else we could do to solve your problem. Maybe someone else can come up with a solution for you. ![]()
Edit: @HDRock do you have any suggestions?
Do you have cameras at your camp as well?
Hope so
Thanks
Never ran into that problem, I would try factory reset on each camera, do one first to see what happens .
Then again that might not help at all , could be a router problem or LTE
could try flashing firmware back to an older one
Yep, really hard to say at this point for sure. Thanks.
How do you flash old firmware back to cameras
Ok
Thank you
Thank you
Youāre welcome.
