Question about cam sequencing
Is there any way to have the app sequence through my three cameras on my phone or tablet. I like having the cams on all the time but I am worried about the image burn on my devices due to the app not letting my screens time out. Thanks.
That can be done with the TinyCam app on your tablet. You can also view 4 or 9 at the same time.
I believe tinycam will do that, it’s a 3rd party app.
Thanks for the information. Is there a way to do this or use this app on the Echo Show?
If TinyCam is available on the Echo Show. I’m not sure if it is or not. The last time I looked into it, sideloading apps is not available on the Echo Show hardware.
Then this is a feature that the Wyze Cam app needs to add in my opinion. Thanks for the info.
What is tiny cam?
There is a place in the forum to make suggestions and see/vote-for ones others have made. Check it out Here .
Search on your idea first before posting a new one and don’t forget to vote for what you like!
