QR scan failure
I switched wifi and cannot get my doorbell cam to read the qr code. Frustrating to no end. Is there a manual option to finish this??
Welcome to the Forum, @omc251! :wave:
Which doorbell model do you have, and what troubleshooting steps have you attempted so far? I didn’t see a mention that you did a factory reset to put the device into pairing mode, so I’m not quite sure where in the process you’re stuck.
Make sure you do not have any zoom/magnification set up on your phone and that the entire QR code is visible. Privacy screen protectors can also interfere.
Thanks all…after i found the suggestion of a focus problem, i did place my phone agaist my dark colored tee to eliminate background and that worked great!
Glad you found a solution. Thanks for letting us know.
