For the Wyze V3 cameras I attach these to a tension rod (magnetic) and I am good to go. For the Wyze Telephoto I have to buy a Holicfun 1/4" adapter ($6) or so – OR take the base of the V3 and put it on the bottom of the OG Telephoto and screw it into the plastic. It would be FANTASTIC if there was an optional base for the Telephoto that matched the Wyze V3 natively.
[Mod Note]:Title and tags edited to expand request scope to include all Cam OG models with non-magnetic bases.
Please note that a vote is not automatically added to a new Wishlist topic, so you probably want to hit the Vote button above the initial post.
You may also be interested in this Tips & Tricks topic:
Particularly for Cams mounted indoors and not subject to wind or a lot of movement (which I imagine is what you’re describing with the kinds of tension rods often used to hang curtains), supplying your own magnet might be the easiest option.
I realize that you described a third-party adapter in your initial post and that you’re not seeking that, but I’m going to drop a link to Mount Adapter for Cam OG just for those who might be interested in that Wishlist topic, as well.
