Product Suggestion: Add temperature capabilities to rules
Suggestion: There is demand out there for smart outlets that can come on or off based on temperature rules. For example on at 33F and off at 40F to keep something from freezing. Could be achieved by either adding a temp sensor to the outdoor plug which would be best, but could also be achieved by connecting to weather data. For example, my Tactacam Reveal X v2 game cameras put temp info on the photos it takes based on a zip code entered in it’s profile, so i assume it’s getting that info by referencing a weather service. In researching ways to do this myself, I also saw people wanting a solution for indoors so they could have an oil register, etc kick on in a room when temp gets too low or a small AC unit kick on when temp gets too high, etc. That would have to be done by adding a temp sensor to an indoor smart plug I’d think.
I don’t want to have the cloud involved when it comes to things freezing or overheating so how about this:
https://a.co/d/bXM8wiv
OR this:
https://a.co/d/bTkjvhK
OR this:
https://a.co/d/9RfvYGg
Welcome to the Wyze User Community Forum @jcastina!
A combination of Wyze products can currently do this. The Wyze Climate Sensors can currently monitor Temperature and Humidity and trigger other Wyze devices, such as plugs, On or Off thru Rules.
yes, I understand what you are saying. I have already bought a few of those. What I’d like is the ability to know when they are working which I can’t get without connectivity. Ideally a product would have the temperature sensor in it vs working from web weather data so it could work whether it was connected or not, but being connected, you could change the rules and also be aware if the outlet is on or off.
Agree with needing built in temp or automation option. I have a Wyze outdoor plug connected to heated birdbath. I’d like it to only be on when outdoor temp is below 32. (Birds don’t need a hot tub during warmer days).
Unfortunately, Wyze Climate Sensors only work with the Hub - which I don’t otherwise need (or three sensors). Additionally, they are rated: Operation Temperature: 32°F—104°F (0°C—40°C). So, not really feasible here where it can get down to 20s at night.
If not built into Outdoor Plug, then create automation that will ping weather based on zip (as mentioned before).
For now, my automation is based on overnight hours and I disable it when temps are above freezing.
Dawne
Long time user, device count: astronomical
