We had an extension built on our home - an 18’ x 18’ Sunroom. In anticipation of placing Wyze cams on the outside corners, I had the builders place electrical outlets under the eaves in each corner. So all I need to do now is to add the cams and the outdoor power supplies and I’m all set. But…
There is SOOOOO much cable unused: from the outlet to the outdoor power supply and from the power supply to the camera. [I have to figure out a way to bunch it all up and affix it to the eaves. I hate the thought of that extra wire blowing in the wind, and it will distract from the looks of the house.] What would be ideal would be for Wyze to make the outdoor power supplies with modular cables. That is, you could select a length of cord for plugging the outdoor power supply into the socket, as well as select a length of cord for connecting the outdoor power supply to the cam. Wyze could offer cords/cables in 1’, 2’ 3’ 6’ 10’ lengths so that customers could buy only the lengths they need for their specific use.
Does anyone else see the utility of having a modular design to the outdoor power supply units?
