Problems with connections
Can’t see cameras or base station
What type of camera. The battery powered V2 camera with the base station? Is the base plugged into the ethernet port on the router? Did you set the base and cam up like this?
Since you mentioned Base Station is it safe to assume that you are talking about the Wyze Cam Outdoor v1 or v2?
If so, I would remove power from the base station and turn off the camera. Then turn on the base station and wait for the light to turn blue. Then turn the cameras back on. It is possible the camera has no battery power left, so I would plug it into power and let it charge. Again, assuming you are talking about the WCO V1 or V2 cameras.
