Powering two wyzecams off a single adapter
Hey folks. I’ve already installed a cam facing one direction of my driveway and am now considering placing one facing the other way. Without having to route another power cable I was wondering if I could just use a splitter?
Cheers,
Francis
You can daisy chain them. That’s what the full size slot in the back is for.
Thanks! I did try it but the second wyzecam while the light came on didn’t want to respond. Is there any issue with using the standard power adapter for two or more devices or should I upgrade it to something with a bit more amperage?
Cheers,
Francis
The standard adapter should be able to power two cams. Three would be pushing it. Keep in mind that you lose voltage the longer the run and the lighter the wire gauge in the cables. You may need to use a cable with heavier gauge wire.
