Using Windows 10 Microsoft Teams, my Headphones power off then back on again, disconnecting the session, battery is at 100 %. Happens on multiple computers, works fine otherwise
Are the headphone actually powering off, or just not working with Teams? The reason I ask is that I regularly use a very good pair of Bose bluetooth headphone on this computer, and I have NEVER been able to get them to work with Teams. Also note that in Teams, you have to specify which audio devices to use - it does NOT default to using whatever the current device that you have specified as the Windows default audio device.
Welcome to the Wyze community @snillorrynot!
I have seen other reports of the headphones not working only on Teams calls. As @K6CCC said, make sure the headphones are actually turning off or disconnecting from the device they are paired to.
