Plug+Surge (Power Usage Report)
Others have suggested a Wyze Surge Protector with USB-C ports, which I second, but I would also like to suggest integrating a Wyze Plug at the same time (i.e. being able to control the ports with the app).
Another nice feature would be to integrate Kill-A-Watt functionality, i.e. the ability to get power usage reported back to the app.
[Mod Edit]: Title Modified to Enhance Search Clarity.
You can vote on your own wishlist item ya know… :slight_smile:
All sound like great ideas, voted. Why shouldn’t all smart plugs have built in surge protection or power conditioning.
A post was merged into an existing topic: Wyze Plug - Expand History (on/off times, power usage, usage stats longer than 7 days, etc.)
Another company makes switchable power strips with individual switched outlets and power tracking as well as USB outlets with power tracking. Seems like a win if Wyze would get on that.
Related wishlist item for reporting: Outdoor Plug usage history should not reset on the first of the month
