I want to see a wyze dual outlet plug, if possible with fast-charging dual usb ports, and timer. Each outlet can be controlled independently.
Welcome to the community, @aintalmd73. I have approved this as a separate #wishlist topic from this one, USB-C Ports (Surge Protector, Smart Plugs, Cams), because you are requesting for multiple regular and USB ports. ![]()
Wyze Plug with Multiple USB ports
I have search but not found anything about this so hopefully it isn’t a duplicate. I am wondering if there are plans to release a wall plug (single or double) with USB ports integrated? I think that would be a good addition to the line up of products because it would allow a electrical connection and also a place to power a camera as well!!
Wyze smart plug with USB port
Hey All
I just wanted to reach out and say great product (cameras v2, pan cam, and plugs). Now that I see you have a hard wired switch, I’m guessing there is a hard wired plug (receptical) is in the works? I’m hoping it will have a couple usb ports on it.
I would like to see the indoor plug have more than one outlet. If Wyze can do it for the outdoor plug, I would think it would be easy to do for the indoor ones as well.
This is something I could imagine using if the form factor was done well. If the USB ports had adequate power output, then I could also see this as an alternative for powering Cams, and the ports could be USB-A or USB-C (or one of each) to accommodate different use cases. Ideally, each outlet and port within the device would have independent app-controlled power switches so that it would be possible to power cycle a Cam plugged into its USB-A port, for instance, without disturbing any other electricity use routed through the device.
I’d still really like to see smart plugs with integrated night lights, too.
Yes, that all sounds great! You would think with all of their other great products, this would be a no brained. I use several plugs now and would love to see this.
