Playback Issue V3 30 min offset
Not sure if this is unique to my time zone, but when I try to use playback the time selection scroller does not synch with the actual recorded time. If I pick a specific time, it will play until the minute changes and then jump to a different time a half hour offset. Example, if I try to play video recorded at 5:00 the time code will say 5:00, but when it reaches 5:01, it will jump to another clip a half hour offset. My timezone is a half hour offset most time zones and was originally unsupported - I am unsure if that might might be the source. Tried reformatting the SD, deleting the devices from the app and setting them up again, deleting the app. Nothing worked. Is this a known issue? What is the solve. I already have the most recent firmware.
I am having exact same issue on two of my wyze v3 cameras. The OG is not affected . As with you my time is on a half hour offset (st johns nl) so I suspect its a software bug with the app. For a temporary workaround i set my v3 time to EDT so at least I could replay the video. My app still runs on NDT.
Hope wyze fixes it soon. Seems to have started with the new app
Correction: i set the v3 time to adt (halifax) which is 30 minutes earlier than the phone/app time. This makes the playback behave better but still shows incorrect time. Not sure how to report this to wyze
