Is anyone else having issues with moving objects such as people and cars, showing as pixelated? The images are not clear but everything else in frame is perfectly fine, My camera is the Cam v3
Are you noticing pixelation during Live View, Cloud video playback or SD card playback (or all three)?
Is the pixelation occurring during cloud/event or SD clip streaming?
Live view and SD card playback
For Live View try reducing the resolution. I have one Camera set to 360p because it is in a weak WiFi part of my house. Seems to Live View stream better set to a lower resolution.
Poor WiFi might also pixelate SD card playback too.
Try to toggle “Account” → “App Settings” → “Enable Hardware Decoder”.
I believe the OP has an Apple device. Hardware Decoder would only be available on Android.
I adjusted setting to 360p. We shall see how it goes tomorrow once there is more movement during the day. Fingers crossed.
Turns out, the issue was with the Wyze SD card. I swapped it out and the issue is resolved.
I only use High Endurance SD cards like SanDisk in all of my cameras. My oldest SD card is set to Continuous Recording and 2.5 years old.
I am having this issue with live view on a Cam V3, but only on my iPad. Moving objects in the live view w will be very pixelated. Closing the app and restarting my device seems to help temporarily, but the issue comes back eventually.
Viewing the live feed from my iPhone 14 Pro Max and Pixel 7a are fine, but on my iPad Air 4th gen, it is pixelated, even when I’m viewing the live feed at the same time on all 3 devices.
I thought I fixed it longer term by logging out, uninstalling, and reinstalling the Wyze app, but that was only temporarily resolved. The pixelation came back after a couple of days.
Will have to test if pixelation occurs when viewing SD card playback as well when it is pixelated during live view.
Pixelation of moving objects does NOT occur during SD card playback for me when it is affecting live view on my iPad.
