I had my router/modem replaced by ATT today due to issues. These smart cameras are too dumb to reconnect so I had to reset both. I was running unupdated firmware. I could get neither to connect. A phone call to WAZE tech suggested either it was a 5GHz or security issue. I checked and though the router is both 2.4 and 5 GHz that was not it. I finally figured out the problem. First I dumped the app (probably not necessary). Then I realized that small L and capital i look the same on my Iphone text. That was the last character in my router address and, apparently, I chose wrongly. I was so elated when I figured this out, that I took the risk of updating the firmware. Both cameras work. Yay! & phew!
Related topics
| Topic | Replies | Views | Activity | |
| Onhub Router | 3 | 790 | April 13, 2018 | |
| Won't connect with new router | 8 | 2654 | September 20, 2018 | |
| Cams will not connect | 2 | 135 | May 28, 2025 | |
| Help with reconnecting cameras to Wifi | 22 | 544 | October 19, 2025 | |
| After updating router, cams no longer connected | 3 | 336 | May 12, 2024 |
