Pause/Disable an Event
I have a event that turns off certain Cams 8am to 11:30PM. Works great and stops hundreds of notices during daytime while home. My question is, I was told that if I go to the “Enable” tab and “disable” that doesnt stop this rule. I need to confirm how to stop this event while on vacation so cams record 24/7.
Last I heard was in order to do this I actually have to “delete” this rule and add it back when I am back home. Seems a bit silly, extra work. Why is there a “disable” tab if it doesnt actually “pause” this event??
If you are in the automation and disable the Automation, it will disable the automation from running.
You do not need to delete any rule, disable stops it.
Make sure to “disable” the automation AFTER the automation runs so that you disable it when the notifications and everything are enabled. If you disable before it runs or while all your notifications are disabled, then they will all stay disabled and youd have to enable all the notifications manually or atleast make a shortcut automation to enable everything you want active when you are of vacay.
Good point! Hadn’t thought of that. :thinking:
