Pan suddenly rotates
Why would my Pan camera suddenly start rotating one direction, reach the end and then rotate back to its original position?
This is the second Pan I’ve had that did this.
I DON’T have motion detection on or anything with this camera.
Thanks
If the camera is rebooted, it goes through its motion reset which would look like this. The first thing I’d check is that the power connection is stable and solid. You might want to try changing power adapters or cables.
So the implication being that there might be a problem in its power supply (cable, surge protect, outlet, etc)?
That’s my first guess. If it’s not that, then factory reset or flashing the firmware might solve it. Instructions for both can be found in the Support link at the top of this page.
