At least once, if not twice a week, the camera suddenly turns all the way to the left then back to the right before stopping again in the middle. Does anyone knows why this is happening? Like it’s resetting itself or restarting. But it has me concern. Or wondering if there’s someone on the other side watching me without my awareness… Thanks
Hi @Captcoolhand. That is a Pan’s reset cycle that you’re seeing. Here are some things that might cause that.
- Power fluctuations
- A power source that is either going bad, or is not supplying enough power. Check to make sure you’re using the power wart included with the Pan (2 amp output), and not a V1 or V2 one (1 amp output)
- An SD card that is either going bad, or needs to be formatted
