Pan cam v2 went out of control after firmware 4.49.3.4054
after updating to firmware 4.49.3.4054 the camera lost its old settings and I cant find the right settings I had before. It now will randomly scan the room and stop facing the wall. It was fine in one position to see the whole room and I was able to move the camera from my android when I needed to. At this point it is useless for what I need.
Sounds like motion tracking is enabled now? Did you not have it enabled before? The setting may have reverted when the firmware was updated. If so, you can disable it.
I did not have it tracking. I can enable tracking and it tracks. it now is facing the position I need but it still will spin around and then stop in the correct position. I don’t need it to move on its own. Like I posted earlier this happened shortly after the upgrade.
