My Wyze Cam Pan v3 camera will no longer tracking motion. The will also no longer pan or allow me to set way points. It use to work perfectly. I tried everything suggested under suppirt help. Firmware update. Motion dectection. Motor control. Reset device. Unplug, replug. Reset as new device. I’ve tried EVERYTHING. Nothing worked.
To clarify, will it no longer even let you set a waypoint at whatever position the camera is currently in, or will it just not let you move it to set them?
When you reboot the camera, does it go through its full “calibration” where the camera moves all the way side to side and up and down?
If movement is its only issue, only thing I can think to suggest is trying a new wall adapter (any USB adapter that puts out 2000MA/2A or more). If that doesn’t help then it sounds like it may have died, but typically you’d think only one motor would go, not both at the same time, but not impossible. If within 1 year they’ll replace it under warranty.
