Need help with V3 pan camera program
I have two V3 pan outdoor cameras and have no problems with one of them but the other one will often change waypoints as if following me. But it will not go back to waypoint number 2 by itself or follow me again. I have to go back to the app and change it to waypoint number two. I have the Track Motion in the black. I have tried reset and also have unplugged it and plug it back up. I thought at first that it was fixed until it did it again yesterday. The settings are same as the other camera. Any suggestions from anyone?
Do you have both pan/scan and track motion enabled? If so it should scan your waypoints, follow any motion, then return to the previous waypoint after like 10 seconds of no motion and continue scanning.
If you don’t have pan/scan turned on, it will return to wherever you manually pointed the cam last after tracking motion.
If you have both enabled and it isn’t working as expected, there was an app update quite a while ago that made it so you had to delete and recreate your waypoints. So you may want to try that.
I have pan, track, and detection settings turned off and it still does it about twice a week, more or less. It messes me up because I might have missed any activity that might have triggered the camera in the waypoint I wanted to monitor. I just never know. If I didn’t have to climb a ladder, I would change it with another camera or something. If it didn’t sometimes (not all the time) try to track me, I guess I could set all waypoints to the same area. I’m just hoping you can tell me something else to try.
Oh I misunderstood, so you want it to stay in one place and not move on its own at all, you’re just using the waypoints as easy ways to move it manually?
But it appears sometimes motion causes it to move from one waypoint to another?
I’d say delete the camera from the app (which should also factory reset it) but you’d have to get close enough to it to scan the QR code in order to re-add it, which sounds like it isn’t possible? Can you delete your waypoints, reboot the cam, then set them again from scratch?
You are correct about getting close to it. I fell off the ladder when I finished installing it and before I got to the bottom of the ladder and ended up going to the ER. No broken bones or brain bleed but had some skin repair. I’m okay now. But I will do as you suggest. If that doesn’t fix it, I will give up. It’s odd the other exact camera, purchased at the same time, has never done that. I have them both set the same way and it’s easy to get to without a ladder. That’s how unlucky I am. Smile
Glad you came out of that fall okay. Before you redo the waypoints, one thing worth a quick look: check Rules in the app for anything that includes that camera, and whether anyone else has the cam shared to their account. With pan, track and detection all off, a rule or another person tapping a waypoint would move it like that, and it would also explain why the other camera with the same settings never does it.
Thank you for that thought. I checked my wife’s iPad and it’s set like my phone. But I did learn something. If I turn on detection zone and put a small number of squares in it, the pan nor track will work. If I try to turn either one on, it will say that with the detection zone on it requires the camera to remain stationary. So …. Maybe this will cure my problem. What is your opinion?
Yes if you enable detection zone, it will disable motion tracking and pan/scan and it will stay wherever you’ve put it. I’m not sure how it affects manually changing waypoints though.
You can set the detection zone to just have one single greyed out square in an area you don’t care about and see if that resolves your problem. It is a workaround, but if it works, whatever. Just see how it impacts manual waypoint changes, I think it may cause it to move back to the “detection zone” position after 10-15 seconds. So make sure it is aimed at whatever you want to be the “home” position before setting that.
Still think it is worth re-setting your waypoints just to see if that’s related, shouldn’t take long. If you have more than one device viewing the cam, there could be something there too, check her ipad for any automations that might be set. I’m actually wondering if you tap a waypoint, then she manually moves it (or taps a different one), which one becomes the “master”. In theory each one should just take over control when it is used. Maybe she’s just watching you while you’re out there :slight_smile:
Thank you so much for your help. I seldom change waypoints. But I will try to do as you suggest to just see if it fixes it. My wife doesn’t do much with the cameras. She mostly looks at the front porch to see who’s here and that’s about it.
Or so she says :slight_smile:
Laughing out loud. Good one.
