Pan Cam V1 powers off after only a few seconds
I have several Pan Cam V1’s at home. A couple of them go offline frequently while others do not. I’ve changed the cords & power adapters for the two not working with cords & power adapters from working cameras but the two still do the same thing.
It will power on initially, then go to a blue light then a yellow light, and then off. Sometimes it will stay on long enough to let me add the camera back, other times it won’t. In the app it just says the camera is offline. When I’ve been able to add it back, it may stay on for a few minutes then show offline.
I’ve restarted the router & access points multiple times without it making any difference. Although they are a couple years old (and naturally out of warranty), they are in a direct line of sight to the router with no walls or doors in between. Each is probably 12-15 feet from the router max.
Any advice? It’s like the power converter in the clock is flaky. Or something…..
That happens to mine sometimes, too. I see you’ve tried the power adapter and cables. Leave it disconnected from power overnight.
If that doesn’t work, try a manual flash of the f/w.
https://support.wyze.com/hc/en-us/articles/360031490871-How-to-flash-your-Wyze-Cam-firmware-manually
