Since the newest update, my pan cam rotates 180 degrees from where I set it to monitor. I have reset it to the viewing area more than a dozen times. I can’t seem to get it to stay. Does anyone have a fix for this?
Check to see if the Detection Zone has been set. If it has either turn it off or point the camera in the direction you want it to be in.
Thank you. I have tried turning the detection zone both on and off. I get the camera pointing where I want it, and it always turns to the right a little bit. Then when I correct it and leave it alone for awhile, the next time I check it, it is pointing towards the wall again. A 180 degrees opposite of the area I have set it in.
Set a single waypoint where you want the camera “home” to be. It should return there after inactivity.
