I’ve had a pan cam running for years, it’s the first one I bought from Wyze. Every day at 5am the plug its on (now a Wyze plug) resets it via an Alexa routine. This fixes the ongoing issue with sensors connected to the bridge failing.
Today I hear the voice telling me that the cam is ready to connect. Go check it out and it’s stuck in a boot loop of initial on, spin to all axis, say “ready to connect”, then reset and repeat.
I’ve tried giving it a QR code which it accepted but it still resets.
Anyone else seen this behavior? Can I hard reset it? It’s mounted on a wall and it’ll be a task to get it down so I’m looking for soft options before I do that.
