Pan and tilt base mounting bracket for straight connector
Fix the Pan Tilt v3 camera. The base is overly cumbersome, the first 90 deg cable was doa so I ordered a third party that worked for a couple of months before the second failed, then the same with the third. I drilled a small hole behind the mounting hole, used a straight cable, keep it simple.
Make sure you vote for your wish as the system does not add it for you
