Broken base bracket
I’m trying to find a replacement mounting bracket for my cam v3. The base cracked while I was adjusting the angle of the camera.
A dumb contractor caused a leak at my home and ALSO broke my cam base bracket too.
All at once man… can’t find the part.
Get one of these or get one from WYZE
Looks like the OP has a regular v3. This might work better.
I have two like the link I posted and use them on V3 cams, Remove the screw on the bottom of the cam and screw in the mount. 1/4-20 shaft.
I keep a couple of new v3 cameras on a shelf ready to put in service. I have not had a v3 die or break in 2 years. When one does I will keep it on my shelf to use for parts.
I haven’t broken any either, I just needed a different way of mounting the cams on the sides of the house to get the correct field of view. :upside_down_face:
thanks, I will try this with my regular v3 cam that someone broke (knocked it down with a ladder and broke the plastic ring on the swivel)…
180.71 I hope that is Pesos :astonished:
HAHA indeed. MXP, Mexican Pesos, it should be something like 11 dlls with free shipping if you’ve got Prime.
The mounts work really well for me, I am happy with them and they are more adjustable than the original mounts. Good Luck.
Thanks!
I just love the factory ones, very compact, discret, magnetic, etc… but this will work too.
