Outdoor Cam magnetic base not replaceable
I have several V1 Outdoor Cams. Today, the clip on the magnetic base that clips on to the support attached to the wall broke. I called support and they said they no longer support V1. I told them the magnetic base is the same as on V2 and they said they did not have the base from it available either. So the bottom line is that if the base breaks you just have to buy another camera. That is not good product support.
I have 3 WCO Version 1 cams mounted on these, They screw into the threaded hole on the bottom of the cam, very adjustable. Do a internet search for Wyze Cam Mount. Some like this, they work on the WCO also.
Thanks a lot. I ordered them.
