Hello,
Can I buy an extra magnetic mounting base for the Outdoor Cam V2?
I want to be able to move the cam from one magnetic place to another.
Ian
I don’t believe Wyze sells extra bases for the outdoor cam.
The base uses a keyhole type mounting mechanism, so you could simply slide the base off the screw to move it to another location. This is probably the easiest way.
You also may be able to find bases on eBay or other sites.
