Yes, another question about the disk! I get how you mount it to the wall but I don’t get how you attach the camera and the base. If you use the magnet in the base to connect to the disc then their is no way to attach the camera to the base. Help
What camera are you talking about? The Wyze Outdoor Cam comes with a base, with 2 screws, plastic anchors to screw into the wall, I use 1 screw and no plastic anchor. The base magnet attaches to either the top or bottom of the camera depending on how you want to mount it. Are you talking about a V3 ?
