For Wyze Suggestion Box: The wall mount plate and wall mount plate tape (mounting bracket, adhesive), would be a very good accessory to consider to sell separately, in case you need to move cameras and you are limited to not doing it because you don’t have the tools. No kit. Only those parts
This works for V2, V3 and V3Pro. Probably will work for the V4 ?. I installed all but one of my cams using the provided screws and hung the cam bases on the screws, tightened down. I did mount one cam on a 1/4 -20 screw on mount.
Bummer. I always throw my mounting hardware in the trash. I could give them away if I knew there was a demand.
I have a bunch of the round plates and the adhesive still in the boxes, 8 off them I think. Also My four old WCO v1 cams each came with a 5V-2A power adapter and I have only used one for charging the cams. I think I used one to power a V3 with a longer cable.
I also have most of the washers and all the adhesives. In some places I used the washer as a reinforcement. I have all the original wall warts as I replaced them all with 5V 2Amp chargers.
