Can someone explain how to get the band to track outdoor running? I only see indoor run. I tried using indoor run but it’s way off on distance and pace. If I cant get somewhat accurate numbers, its worthless to run outdoors with it. Can you see google fit on the band while you run? Or does it only exchange data?
Any update on this?
Related topics
| Topic | Replies | Views | Activity | |
| How to change running from 'Indoor Running' | 5 | 648 | May 13, 2021 | |
| Wyze Band Fitness Tracker modules | 25 | 3115 | April 20, 2021 | |
| WYZE Band & Scale - SYNC, Feature and Options | 2 | 741 | November 30, 2020 | |
| Google fit syncing with wyze band | 47 | 7881 | February 10, 2021 | |
| Run Mode | 3 | 1028 | April 13, 2020 |
