Outdoor camera on wire
Some question about Outdoor wyze cam.
Can you keep them connected on usb for electricity or you have to always run on battery ?
The Wyze Cam Outdoor (WCO) was really intended to be a battery-powered device. While you can power it continuously, this would leave the camera vulnerable to damage as it requires you to pull the rubber cover off of the charging port.
A much better option is the V3, which is designed to be weatherproof while powered. The V3 also has many other benefits because it is expected to be continuously powered, and is of a newer design.
Thanks for the complete answer !
