One of our outdoor cams won’t charge anymore. The red light flashes, but even after hours, it has no charge.
It is almost 2 years old. Model wvod1.
Thanks.
Thanks.
Are you using the Base to charge it?
If you haven’t tried another micro usb cable, also try turning it off to charge if you haven’t already.
I have solar panels on all of mine now, but in the past I had an issue where the camera didn’t charge and turning it off first worked, so I just got into the habit of turning them off to charge before I got solar panels.
Yes I always turn them off before charging them. If you’re not using the base to charge it, try that. You also may want to try using a higher amp power adapter, like one for an iPad or laptop.
I’ve had 2 Outdoor Cams for years. I thought I had the same problem now after it was plugged in to charged and it started to go lower still. I went over and pulled out the charger and jiggled it back in making sure it was seated well in the camera. Now, it’s charging normally again.
