Outdoor Cam V2 not charging
Bought an Outdoor Cam V2 in June 2023 and it worked fine until one day it just stopped charging. Is it a brick now or is there some way to try to resuscitate it?
Can you plug the cam into another power source to see if the brick failed. For instance, a PC or other USB port?
I’ve tried a couple different power sources. No go.
If you tried different power sources and tried a different cable, maybe it’s time to take it apart for inspection.
Did Wyze support offter you any options ? Like what to try or offer a replacement?
