Hi, i have an Outdoor Cam fitted with a properly formatted SD card. In the Wyze apps i can’t access the time-lapse function. I got a grey screen and have to kill the wyze app on my phone. It’s simply impossible to configure it properly.
To confirm, the grey screen occurs when you press the time lapse button off of live view? Then the gray screen shows up before the time lapse settings do? Have you updated to to new app? What app version is on your phone, and what firmware is on the camera? Have you tried power cycling your phone?
Yes, the grey screen occurs when i press the time lapse button.
Yesterday i updated both firmware (base + cam) and the apps on my pixel 2 XL
I also enrolled for beta apps in google play.
I cycled power my phone every night and i am using Android 11 but i have this issue before upgrading to 11.
Since the activation (2020/08/14) i never been able to use time lapse with this cam.
thanks for the screenshot. After you kill the app, and reopen it, can you submit an applog - from account-> help & feedback → submit a log → then post the log ID here.
