Out door cam
Apparently ordered d out door cam but it seems that u need a base for cam to operate never knew thought it was just similar thinking that it will just operate with WiFi that’s not d case.
Welcome to the forums! You are correct, the WCO camera needs a base to be installed. Currently the base stations are only offered in the wco started pack. The base station gets hard wired into your network via an Ethernet cord (current info as of 12/14).
