Options for the Wyze Hub
Anyway we can get options for the Wyze Hub? I would love to be able to “Set” which sensors make the “Ding” noise… I dont need them all to notify the household…
Thank you in advance!
If you have a Home Monitoring subscription, you can define which sensors trigger sound on the Hub in Home Monitoring settings > Tune Settings > Entry Sensors > select a sensor > toggle Entry Notice on/off.
If you don’t have a subscription, you won’t see this option. You can show your support for providing this feature to non-subscribers by voting for and/or commenting on the associated wishlist topic here:
Thanks for that info! I pay for cam Unlimited… I also have the option to click on the monitoring down below for my app… I don’t have a “setting” for the hub that allows me to change the “tune”. I tried clicking on services under “Account” it only shows me my Cam Unlimited sub and no option the purchase the home monitoring…
You need a Home Monitoring subscription in order to change the Hub’s tune settings. If you already have the Home Monitoring system hardware, you click “Already have the hardware”, not “Build my system”. And if purchasing a subscription, please do it from an Internet browser, not via the Wyze app. You also need a US or Canada-based address to make use of the subscription.
