I just received my new Wyze Cordless Vacuum S (WCVV2CD) and really like it for quick, daily cleanups in between weekly deep cleaning with the full-size vacuum. Do any other “S” owners in this forum have any advice regarding a wall-mounting option to keep it off the floor and charged in-between uses?
Please note that, for the price of the “S” vacuum, I did not expect the inclusion of a mount or charging stand. If any Wyze product engineers happen across this post, if you decide to make a wall-mounted or free-standing charging station for the “S” model vacuum, I’m quite sure it would sell well.
Thank you in advance for any suggestions from the Wyze forum members. I appreciate your time and expertise.
You might check out the 3D printed mount on Etsy:
carverofchoice, thank you so much for the solution! I had searched Amazon and Ebay, but it did not occur to me to check Etsy. I ordered one of the mounts and will post back to let others know if the mount works well with the Wyze Cordless Vacuum S.
That sounds great! I’ve suggested this mount to a few people, but nobody has yet told me what they thought of it. I’d love to hear your follow-up since you’ll have first hand experience with it.
Hi that is my Etsy shop and mount I have designed for the Wyze cordless vac. If you have questions about the mount please message me on Etsy. I designed this mount for the original Wyze cordless vac because I hated the mount Wyze shipped with it. My mount is designed to have drop in charging for the vac and storage for all the attachment. The s version of the vac is missing the wall mount and 1 attachment, but is the same vac. My listing comes with a separate holder for the floor attachment included. No need to buy an extra, but you have the option. I also have many other Wyze related 3D printed products. Also if you have an idea for a Wyze related 3D print please reach out to me. I also recently expanded into the laser engraving/cutting side of 3D printing and have new items posted for sell on my Etsy shop.
Yes, I have your shop and several items bookmarked.
They have been very useful add-ons for the Wyze stuff I have, and I recommend some of them when they are applicable to people’s needs like this. Thanks for designing useful stuff for everyone. We appreciate it.
Hi, I figured out a way to create a flexible hose from the vac that works with the original attachments. Here is the link. I am also working on set of detail tools to go with the hose.
Found this conversation while trying to find the Wall Mount myself, but after arduous searching I was still unable to find an STL for a “S” compatible Cordless Vacuum.
So I gave up and just created it myself, Wyze Cordless Vacuum S Wall Mount, print & enjoy!
Thanks, I found your design and printed it. It is working great, but I did need to use supports for the cord holder and the angled tab. I am a little worried about the tab breaking off, I hang my vac with the power head attached.
I created an adapter so I use use the brush tool and flex tube from my Rifgid small wet/dry vac. Here is the link: https://www.printables.com/model/712114-wyze-cordless-vacuum-s-crevice-tool-adapter
Why do we have to buy a wall mont as it will not stand on its own? Why didn’t this S vacuum come with the wall Mont and a sofa brush? Why does the S charger not work with the original stick vacuum and vis versa? Not happy with Wyze and I have to much of their stuff!
Garry
I agree hami2088. The vacuum can’t stand on its own, why isn’t there a mount available? I understand they had to remove some accessories to get it under price for Walmart, but it should be available in the Wyze shop for those of us that expected one, like the little brush.
Plastic coat hook and a few drywall anchors = problem solved.
NICE! That looks like it works great!!! That’s a great idea. I might actually go do that now. I DO have an official mount, but sometimes I want to hand the vacuum in a different spot, and this will be perfect.
