I have 4 WyzeCams 1 upgraded to beta firmware 3.9.2.30 but the other 3 are still on 3.9.1.102 and don’t offer an upgrade.
How do I force the other cameras onto the beta. Using beta 1.2.32 on my phone.
Did you tap the settings (gear) icon on the camera, then Device Info > Update firmware > Check upgrade?
That option does not appear to exist. After going into device info there is a firmware upgrade title showing the current firmware but it cannot be tapped.
Did you try power cycling both your phone & camera?
No change after power cycle. So everyone can check for a firmware update on the beta 1.2.32 android app?
That’s exactly how mine looks except firmware is 3.9.1.102 in both places, not showing an available upgrade.
I’m having the same issue. I’m on the beta, my other two cameras are on 3.9.2.30,but my third is on 3.9.1.102. I’ve done a hard reset on the camera, rebooted my phone. Deleted the camera, added it back and it still won’t update to the latest. Any ideas?</span>
Same problem here no firmware update on ether of my 2 cameras version 3.9.1.102 any new ideas?
EDIT : after app update to vers 1.2.47 both camers updated firmware to vers 3.92.30 and are working perfectly !
Hi. I cant connect my second camera. Just hear (Please wait to connect).
