I have three Wayze cams (1 Wyze cam and 2 Wyze Cam Pans). One of the Wyze Cam Pans has stopped sending push notifications or recording while motion is triggered. The camera still moves and tracks motions. Also the live feed works fine.
So far I have done the following steps:
1- Unplugged/Re-plugged the camera
2- Removed/Re-added camera to the app
3- Did a factory reset of the camera
Unfortunately none of these helped.
Has anyone else had the same issue?
