Hi.
Can the spotlight on the OG camera be turned on/off manually from the app or is it motion triggered only?
Also, what is the reach/distance/area the spotlight on this camera supposed to cover?
Thanks!
Yep, it’s on the live view page.
I’d say it’s similar to the IR illuminators, which is 25 30 ft ish. The starlight sensor will really help it though because that improves the picture in all low light situations.
Thank you for getting back to me with answers I was hoping for.
Cheers!
