I’ve been trying to find the WiFi settings options so that I can connect with my new router. Do I need to uninstall my Android app and start from scratch or can I make the change in the app?
You don’t need to uninstall anything.
You can either chsnge the SSID and Password on your new router to match the old one or;
Add the cameras to the app like you did when you first got them. Give sames names that they have now.
I would change the router settings.
Thanks so much for your response.
I have several devices already configured to work with my new router so I don’t think the first option is a good one, but the second one sounds doable. But to clarify, do you mean I need to disconnect my camera altogether which brings the question; how do I do that) then start over; as in “Add a Product”?
btw I wish WYZE would abandon the pretty abut VERY difficult to read pale green color. I can barely read setting options!
Yep, to add your devices to the new router you need to do the add a product and go through the QR code scan and all. If your cameras were already installed, no need to delete them, just add new product.
Ok, Thanks again for you help, I really appreciate it!
I agree on the horrid app colors.
There is a wishlist for Dark Mode.
Go vote.![]()
https://forums.wyze.com/t/app-dark-theme-mode/8439
Thanks, I added my vote!
Force Dark Mode is only available on Android 10+.
Thanks, but this option appears to be universal, not just for my WYZE app.
I know and it’s not great with some apps.
