Hi, I have the V4 model that I just bought this camera and I have a problem to view the video recorded on the SD. Slo says “No video available at this time”.
Do you have a solution?
Best regards
Javi
Best regards
Javi
It won’t play. I’m going to try formatting the card from the device and see if that solves it.
The problem was the SD formatting. I have now formatted the card and it is recording and playing videos. Thank you very much for your help.
great ![]()
Could you screen capture your microSD card again on the “Manage SD card” or “Gestionar tarjetas SD” page ? The size of your microSD looks abit off, but it could be due to it being corrupted.
128GB microSD card should be ~119GB (binary)
That seems to be a fake card from Aliexpress ? According to Sony’s website, they don’t seem to make any microSD cards that I know of. Also, I highly doubt they want to use a colour scheme similar to SanDisk.
It is from Aliexpress. I have requested a refund and will try another more real one. I’ll let you know.
