No sound in live view
Hi guys!
I have 4 V2 cameras and none of them have any sound whatsoever in live view. Yes the sound icon is on… What gives? Any feedback would be greatly appreciated. If this is a known bug please let me know… Thanks in advance!
No idea but perhaps you should trade equipment with this guy.
I have 3 with the same problem for a while now. Don’t have the patience to try to troubleshoot right now because their troubleshooting for this issue is pretty lengthy before you reach out to them. If you find a solution let us know!
Thanks Lari for confirming that I am not the only one with this issue. I have sound if the cams record an event but none at all with live view so I don’t think that this is camera (all 4 are affected the same way) related but app related somehow. Just wish I could get some answers or they would fix the issue!
Have 3 version 3’s wired Wyze cam’s all new in last month. No sound in Live View— either. Just static. If I click to unmute SPEAK I will hear outside sounds for like 1/2 a second. Did resets, restarts, factory resets, other cables and so on. All 3 have same issue. Shame.
Do get sound in recordings though.
Also noticed very poor volume if you try to speak to someone from the app.
Company should put out a better product, fully tested even if it is $25 more . I now have about 5 cameras (version 2 and 3’s) and no more.
Peter
I am having the same issue since the latest update. I have no audio for live viewing, but when I review recordings, the sound is there.
Is there a fix for this?
