No push notifications when using Cam Plus
Hi,
We have 6 cameras in use, only one using Cam Plus. The one camera using Cam Plus has recently stopped send notifications to android. Can see events but there are no notifications sent.
Any clues?
Welcome to the community @andrew69
Have you tried removing the cameras from Cam Plus and then adding them back? In addition, you can try clearing Cache and setting up the notification options. Here is a link I provided earlier, to another forum member. You can try this to see if it helps:
Hi,
Thank you for your suggestions. I will try them and report back.
Removing the camera from Cam Plus and adding it back resolved the problem. Thank you
