Every since last firmware upgrade, none of my 4 Battery cam Pro’s now do not show any events. Even SD card shows “no events” I was wondering if there is a glitch in the cloud services? I also have Cam Unlimited and all cams set for 14 day retention. My other V4s seem to me ok. However ALL my other cams only show a couple of days which also tells me it has to be a cloud issue? I have sent to logs about this but no response yet. Just wondering if anyone else is having issues seeing 14 days of events.
Since even the SD card shows no events, I’d suspect detection or the Events view rather than the cloud; Wyze posts ongoing service issues on their Service Status & Known Issues support page, and nothing there mentions event recording right now. Two quick things from Wyze’s Battery Cam Pro troubleshooting article: in the Events tab, tap the funnel icon and Clear All filters, because an active filter makes the list look short across all cameras (that could explain your other cams only showing a couple of days). Then recheck the camera’s settings after the firmware update: Event Recording set to Motion > All Events, Customize Detections with Tag and Notify checked for Other Motion, and under Account > Services that your subscription is still applied to each of the 4 cams. If all that looks right, their listed next steps are a power cycle (battery pack out for 10 seconds) and, as a last resort, a factory reset, which clears the camera’s settings and means setting it up again like new (their steps have you remove the microSD card first).
OK I have done these suggestions. Only one I couldn’t confirm specifically under account services as all it says is Cam Unlimited “all cameras”. Doesn’t say how many (I have 13 in all) As of now, 2 of the 4 battery cams are showing events back only 4 days. All other cams, same, 4 days. Over next few days if I cant get any events pas this 4 days, I will remove/replace all of the 4 battery cams.
That’s actually a useful data point: if all 13 cameras show the same 4-day cutoff, including the non-battery ones, this looks account-wide rather than a Battery Cam Pro problem, so swapping those four probably wouldn’t change much. The “all cameras” wording under Account Services is normal: per Wyze’s About Cam Unlimited support article, the plan covers all compatible cams under one subscription and includes 14 days of event video cloud storage. Since everything stops at 4 days across the whole account, that doesn’t match the expected retention, so I’d take it straight to Wyze Support rather than replacing hardware.
I have sent 2 Logs to Support over the last week, but not yet go a reply. FWIW, when I log into Wyze online account I actually do see 14 days of recorded events. Oddly, not in my App. Hence why I was suspicious of a bug in my Android. I did clear “data” and relogged back in with no results. Also assume to actually delete the App and reinstall might do something, haven’t tried that yet.
Another side note, is now I can go back 4 days to the 17th. But not available to back further. Maybe as the days move forward, I will start to see back further, or in 10 days, be able actually go back to the 17th.
You have to call WYZE Support and get a Ticket # for them to review your Logs.
How do I contact Wyze Support? – Wyze
Wyze Support (US & Canada Only): 6:00 am - 6:00 pm PT Mon-Fri, and 8 am - 4pm PT Sat-Sun
Call Wyze Support:
US: +1 (206) 339-9646.
Canada: +1 (581) 500-1166.
